W
Hello all,
We have been using modbus RTU over utilinet radios for years. We have one master (FIX32) polling many Modicon PLC's (very reliable). We want to add another base radio to a new Quantum w/ Xmit loadable to be a second master.
When I use my PC Modbus software as a master to the radio, I am able to communicate with three Compact 141's (nodes 5, 6, and 8). I am also able to use the Quantum as a master to a software slave using a direct cable connection to my PC. The problem is when I connect the Quantum to the radio, I get timeouts. I know that normally only one master is allowed, but with the Utilinet radios this is allowed.
It has been suggested to use ASCII over radios instead of RTU because of the 3.5 character times issue. Because RTU mode has been working for so long I hestitate to convert the entire system to ASCII.
If the 3.5 character times is an issue, why does FIX32 work in RTU mode?
Might there be a difference in the drivers that allow FIX32 to work, but not the Quantum?
Any suggestions?
Any suggestions?
