Dear Friends,
I m trying to communicate LPC2148 microcontroler with Schneider M340 PLC over MODBUS RTU. I have pasted my program here. My problem is PLC is not getting any thing.
Need your valuable guidance.<pre>
#include <LPC214X.H>
#include <stdlib.h>
long GetCRC(void);
void init_uart(void);
void transfer_485( unsigned char Data[]);
void tx_CRC(unsigned char);
unsigned char arr[]={'1' , '6' , '0', '0' , '0' , '2' };
//int arr1[]={1,6,0,2,0,78};
long a;
unsigned char j1;
int main()
VPBDIV=0X00;
PINSEL0=0X00000005; //P0.0 & P0.1 CONFIGURE FOR TX AND RX
PINSEL1=0X00000000; //PIN P0.30 /RE AND P0.31 DE AS GPIO
/*IO0DIR=0X00FF0000;*/
init_uart(); //INITIALIZESD THE UART
while(1)
transfer_485(arr);
/*ROUTINE FOR INITILIZATION OF UART0*/
void init_uart()
U0FCR=0X07; //BOTH TX AND RX FIFO DISABLE
U0LCR=0X8b; //DLAB BIT ENABLE,PARITY ENABLE,1 STOP BIT,8 DATA BITS
U0DLL=97; //VALUE TO GENERATE 9600 BDR
U0LCR=0X0b; //DLAB BIT DISABLE
/*ROUTINE FOR TRASMISSION OF DATA*/
void tx(unsigned char ch)
char d1,d2,d3,temp;
d1=ch-'0';
d2=d1<<4;
d3=d1>>4 ;
temp=d2 | d3;
while((U0LSR & 0X40)==0);
U0THR=temp;
//THRE is set immediately upon detection of an empty UART0 THR
//WRITE DATA TO TRASMIT HOLDING REGISTER
/*ROUTINE FOR TRASMISSION OVER RS485 */
unsigned char i1;
unsigned char CRC_HI,CRC_LO;
unsigned int time;
IO0DIR=0XC0ff0000; //Select the direction of p0.30,p0.31 as OP
IO0SET=0xC0000000; //p0.30=/RE,p0.31=DE both are high for transmission
a = GetCRC();
CRC_HI=a;
CRC_LO=a>>8;
/*U0LCR |=0x2b; //from init_uart LCR=0x0000 1011*/
for(time=0;time<=10000;time++);
for(i1=0;i1<6;i1++)
unsigned char Snd_Data;
Snd_Data=Data[i1];
tx(Snd_Data);
for(time=0;time<=5000;time++);
tx_CRC(CRC_HI);
tx_CRC(CRC_LO);
/*GENERATING CRC FROM TRASMISSION DATA*/
long GetCRC(void)
long CRCValue=0xffff;
long MLength;
int i,j,Data1;
char Data;
for (i=0;i<6;i++)
Data = arr;
Data1 = Data-'0';
CRCValue = CRCValue ^ Data1 ;
for(j=0;j<8;j++)
MLength = (CRCValue & 1) ;
CRCValue = (CRCValue / 2);
if(MLength & 0x01)
CRCValue = CRCValue ^ 40961 ;
}//end if
}//for 2
} //for 1
return(CRCValue);
void tx_CRC(unsigned char ch1)
char d2,d3,temp;
d2=ch1<<4;
d3=ch1>>4 ;
temp=d2 | d3;
U0THR=temp;
while((U0LSR & 0X40)==0); //THRE is set immediately upon detection of an empty UART0 THR
}</pre>
#include <stdlib.h>
long GetCRC(void);
long a;
unsigned char j1;
int main()
VPBDIV=0X00;
while(1)
transfer_485(arr);
void init_uart()
char d1,d2,d3,temp;
d1=ch-'0';
d2=d1<<4;
d3=d1>>4 ;
temp=d2 | d3;
U0THR=temp;
unsigned char i1;
unsigned int time;
a = GetCRC();
CRC_HI=a;
CRC_LO=a>>8;
for(i1=0;i1<6;i1++)
Snd_Data=Data[i1];
tx(Snd_Data);
tx_CRC(CRC_HI);
tx_CRC(CRC_LO);
long GetCRC(void)
long MLength;
int i,j,Data1;
char Data;
for (i=0;i<6;i++)
Data = arr;
Data1 = Data-'0';
for(j=0;j<8;j++)
if(MLength & 0x01)
}//end if
}//for 2
} //for 1
return(CRCValue);
char d2,d3,temp;
d2=ch1<<4;
d3=ch1>>4 ;
temp=d2 | d3;
U0THR=temp;
}</pre>
