K
I do not have experience with programming, so I may be way off with this (and the grammar). Please give me advice and/or articles I can read to help me better understand this topic. Also, can you explain and/or provide me with information on the differences between the parameters: shorts, floats, longs, bytes, binary, and doubles?
The device is reading incorrectly with the current setup.
The byte order in the monitor is defaulted as BADC, but may be changed. I am using 32 bit floating points and shorts as my parameters. The main thing I am trying to read is an output value for the level of odorant.
We were advised to use the conversion code 67 for the floating points, but I'm not sure if that is right.
I can provide more information as needed. Thank you.
