L
I am facing with a problem as below, could you all please advise me to fix it:
I use Mitsubishi GOT 1000 serial and connect with 2 Delta Servo drives ASDA-A2 400W via Modbus RTU 485.
The connection is okay. However after 4-5days, the connection time out alarm appear in GOT HMI. At this time, I cannot get data from Servo drives anymore. If I want to reconnect, I have to turn off servo drives and turn on again.
Could you please advise what i should do to correct this case?
Thank you and always with my best regards,
Thang
Thang
