MODBUS MB-3100 PROSOFT Module
Monroe Strike
If the scanner does not clear the receiving data area then is there a specific control bit that I need to send to the Modbus module to clear the data area or do I have to create code to send zero's explicitly.
Monroe Strike
FLS Automation Denmark.
K
KrishnaKumar Nagarajan
If the communication is Lost, the same can be found out from the BTR instruction error OR
The first and second words of BTR will not increase in count
Use a FLL instruction in the PLC toclear the PLC data area.
> Monroe Strike
R MODBUS 2
E MODBUS 2
mapleleaves2222 MODBUS 0
Amr Abdelsayed MODBUS 7
M MODBUS 2
