I have a MODBUS MB-3100 PROSOFT module to communicate with an Allen Bradley PLC5-80e on the same chassis, and I would like to know if the
scanner clears the data area when the connection to a particular Modbus slave device is lost.
If the scanner does not clear the receiving data area then is there a specific control bit that I need to send to the Modbus module to clear the data area or do I have to create code to send zero's explicitly.
Monroe Strike
FLS Automation Denmark.
Monroe Strike
