U
I have two different projects, with a the same problem. First off I have to read and write data, from a Siemens S71200 PLC by using TCP/IP MODBUS. The main controller type is GE Fanuc. I use the command Com_req. II need help with the action that should perform in the Siemens controller.
In the second project I have to read and write data from a boiler. The boiler data is in MODBUS 485 or 232. My PLC is again Siemens S71200.
