W
Anyone interested in Modbus can find specifications at
http://www.modicon.com/techpubs/TechPubNew/index.html.
The serial protocols are described in
http://www.modicon.com/techpubs/TechPubNew/PI_MBUS_300.pdf
The Modbus/TCP protocol is described in
http://www.modicon.com./openmbus/
BTW: there are two serial protocols called ASCII and RTU. They differ only at what you might call the data link layer. The higher layers are the same. (Though you won't find any description of layers in the protocol specification, it can be implemented as a layered protocol.)
ASCII is easier to implement, but RTU is about twice as efficient. As a result most low bandwidth applications use the RTU protocol. I'd recommend implementing both, but if you have to choose, pick the RTU protocol.
LinuxPLC mailing list
[email protected]
[email protected]
