I understand that RTU send 8-bit per byte. The problem is when i try to figure out how can i code it. Let's take for example i want to send a message to Read coils 20-56 from slave address 17 in RTU. I have to send this frame:
T1-T2-T3-T4 110100130025{CRC} T1-T2-T3-T4.
Now how can i send this mesage using Delphi such that the frame is only 8 bytes long as indicated in the reference guide? Is it possible to send 11 as 8 bits?
Thanks in advance.
Thanks in advance.
