I have two electrical meters that are communicating to two external users (via DNP3). Each user requires data from both meters. I have two serial ports on each meter.
One of the serial ports on each meter is used for the external communications. I can connect the two meters together on the second port. I can make this work one-way by setting one meter as the master and the second as a slave. How can I get data from the first meter to the second at the same time.
