Hello!
I'm new to posting in forums and I'm also quite inexperienced in working with industrial communications, so I hope someone can help me out.
I have a USR-DR302 RS485 to ethernet converter, however, when I set up the device and try to read values in my computer from the slave device, I keep getting connection errors. I'm just trying to make sure that the converter is working as it's supposed to, but since I can't read any values I'm kind of stuck. To read the values I'm using Modbus tester and Modbus poll. For some context, I'm basically trying to do what this tutorial is doing but with a different converter, do you have any idea what could be going on? The device I'm trying to read data from is a VFD Delta MS300 but I have to read the data using the USR converter, since the VFD is not the final product I will be using it on.
Thank you very much
Thank you very much
