T
I am looking for a modbus simulator that will be able to read extended registers. The modbus systems I work with are serial links as well as over ethernet. I need to test as a slave and as a master. Any tips or thoughts on this? I currently use the Calta modbus simulator, but have not figured out how to read the extended ranges, if it is even possible. Thank you for any information you can provide.
