Modbus Slave
G
Gino Moscardelli
I'm running a Wonderware Intouch Ver 7.1 application and require the WW database to be available to a DCS system. Is anyone aware of any application that can link to the WW database and
make the PC a modbus slave device?
The DCS will act as the Modbus master polling the Intouch PC as a Modbus slave.
Gino,
Standard Automation & Control LLC
(http://www.standardautomation.com)
has a product called: Modbus Slave (for InTouch) Part No. SA01-025 The Standard Automation & Control LLC Modbus Slave (for InTouch) utility is a Microsoft Windows based program that provides an interface between Wonderware's InTouch package
(version 3.2 or later) and a Modbus Host Computer (Modbus master). The Modbus Slave follows the Standard and Daniel's Modbus protocol formats. This program enables a PC running InTouch to emulate a Modbus device and allows a Modbus
master device to read and write values to/from the InTouch runtime database. Note: This product is not a DDE server
Here's the link to the Product Data Sheet:
http://www.stdauto.com/datasheets/ModbusSlaveds.pdf
This may work for you.
Bob Grinde
GS Systems
