HI, I'm reading values from an SBC SAIA PLC ( PCD2.M5540 model). My problem is that some values are 32 bit, while modbus return 16 bit values, of course. Registers are consecutive, so I cannot read for example 9008 and 9009 since they store 2 different information.
To make it clearer I attach the PLC watch window. As you can see R9009 is a 32 bit value, but I can't require R9009 and R9010 via modbus since in R9010 register there is a different information. AS well as in R9008. Speaking with SAIA technical support, they explain me that their PLC registers are natively 32 bit, so in order to read them I need a 32bit modbus client. I cannot find anything like this, neither I can use standard modbus, since the buffer I get back is a 16 bit for each register. So 16bit for R9008, 16bit for R9009, 16 bit for R9010. What I can do?
