P
Hi all,
I just got the Modbus/TCP to lplc interface code to work.
Its still a bit messy and I havent documented much yet but I got it to work
Unfortunately the program needs to have two config files. linuxplc.conf and ioserver.conf. and tag names in both have to match. Its still early days yet that we could mayby combine the two into linuxplc.conf.
The code that I wrote has a toggling bit in it that drives an output that I was testing on and off. Make sure you remove that code when you try driving real io.
I have not studied any perl but I borrowed the perl script from demo/basic and tryed to modify it. Can someone fix it up a bit to make it more friendly.
Let me know if this is what we are after or if its not quite the direction the lplc code should be like.
enough said.
Phil.
LinuxPLC mailing list
[email protected]
enough said.
Phil.
[email protected]
