I need a simple utility to run on my PC and communicate with a Modbus RTU slave to verify commications works with the slave. I only need it as a utility for checking stuff out. Does anybody have one/sell one???
Just Go to "www.wintech.com":http://www.wintech.com and search for modscan application u can download the demo application for on month and there after u an buy on line also.
You can get "Modbus test software" from
modicon support bbs. The program is older and unsuported but works just fine. Here is the procedure you need to follow:
Take a look at the MatPLC, one of the demos does exactly that, so you won't even have to set anything up yourself. (Well, the demo blinks outputs 1, 2, 3 and 4 on RTU slave 0 - you might need to change that to suit.)
Horner Electric has a Modbus utility program that will do what you are looking for. "WWW.heapg.com":http://www.heapg.com"
Go to their download section.
Any of the Modbus Master emulation programs mentioned should do what you require. My favorite can be downloaded from http://www.simplymodbus.ca/download.htm
