Modbus Vs Standard RS232
Normally Modbus is on top of:
http://en.wikipedia.org/wiki/RS-485
That is you can connect several devices to the serial line. Where RS232 only allows to connect 2 devices with each other.
Modbus itself is a software protocol, that may use a serial line or TCP. It allows to address up to 254 slave devices.
If you use RS232 connections you can only connect 1 master to 1 slave.
With RS485 you can connect 1 master with up to 254 slave devices.
bob peterson
Actually, I seem to recall there are several Modbus addresses that are reserved so you really cannot have 254 slave devices. I seem to recall there are 247 unreserved addresses, but I might be wrong about the actual number. If the number I recall is correct, the maximum number of slaves would be 246. But my rememberer might be wrong.
