W
i do a research about process control in my lab. i have a problem when i have to find the model of the plant. there was 2 tank, the process tank (upper) and sump tank (lower). There was a pump which pumping the water from lower tank to the upper tank. Solenoid valve on the upper tank, throw out the water from upper tank to the lower tank.
now i try to find the model of level loop.
this loop contain of an upper tank, solenoid valve (outlet) and the inlet from the pump. and i have to control the level of water on the tank using solenoid valve (outlet valve).
are there anyone who understand about this??
r are there who have the references?
thank you
wildan
thank you
wildan
