P
I am using Modsoft 2.62. The node is set to station #2 via the dip switches on the processor. I have set the dip switches for communication (RS232 via Modbus port) for 9600 which is the factory default. The same is set in the software. The toggle switch on the processor is set to DIP not MEM (I tried it both ways). I am using a cable which I know works and on COM1 on the PC.
When I power up the processor, everything on the LEDs indicates normal (green light, ready light on, modbus plus light flashing) When I try to go directly on line the processor the software comes up with an error message 199, PLC timed out, review processor addressing. Yet I get the Modbus light flash as it's trying to communicate with the processor and PC. I have tried changing the addresses on the DIP switches and in the software but I just can't seem to get online.
Any suggestions... I'm fairly new to Modicon, I usually use AB PLCs but I need this one going.
