I work in a large plant that utilizes mostly A-B slc's and plc-5. While going through some old equipment I found a modicon compact 984 with a bunch of i\o modules. I have been trying to get a configuration running that uses several DAP217 discrete true low dc output modules. The config recognizes these but when I try to start the plc I get a stop code 4000 hex. The config is correct as far as I can tell but no go. If I cheat I can get a run light by configuring the the 217's as 216's but then have no function at the output. Any help is appreciated.
Dan Chaffin
[email protected]
Dan Chaffin
[email protected]
