Moisture in oil detector
R
R.Jayapal
Can anybody suggest a method or supplier for moisture in oil detector to use for online leak detection in Shell & tube Heat Exchanger to trip it if moisture content in oil is above 100 to 200 ppm? This indicates that there is a leak. Oil temperature is 400 degC and pressure 25 Kg/Sqcm. Steam at 110 Kg/sqcm is flowing in tubes and oil is flowing in shell. There are a few equipments available like Kytola, Eesiflo but are for lower temperature & pressure. We prefer a inline or bypass type as the oil pipe size is 760 mm diameter. My email is [email protected]
