Is there a way to implement the same functionality as the IML '==' operator, but from a VB script in the client project?
Why? The Alarms system can 'hide' alarms. The alarms are hidden from the CB Active-X, but are still logged to the SQL. This is exactly what we need, so far.
However, if the tag that causes the alarm is ON at the time the alarm is 'un-hidden', the Active-X does not see this.
I think this is because the change flags have been reset when the SQL log takes place, so when the alarm is un-hidden there is no refreshing of the Active-X.
My proposed solution is to do a 'Forced Write' on the tag related to the alarm which I've just un-hidden. This will hopefully cause the alarm server to refresh the Active-X.
Thanks.
Thanks.
