R
I have a project where we need to move a large (500 elements) array from an external source to an Ethernet based CL5550/L1 processor. The array is sourced from one OPC server and we wish to transfer it to the Contrologix via Matrikon's Data Manager and RSLinx. Having no luck with RSLinx as I cannot specify the Array as a single tag. If I substitute Kepware's OPC Server for Contrologix, it has the syntax for an array as a single tag and I can read/write via Matrikon's Data Manager (OPC Bridge) OK. I can't even see the array as a single tag using RS OPC Client. Is there no way to accomplish my task with RSLinx. If it's the difference between Kepware and building 500 tags, Kepware is going to win.
