X
Our unit MW output drop by 6-8MW within 1 minutes after the unit go into temperature control. In our opinion, the unit should be able to produce a higher load at baseload instead of partload.
We have done a few recommendations from the OEM but the problem remains there after each of the tests we conducted and not showing any improvement at all. We have done the following:
1. Perform offline compressor wash.
2. Perform calibration on the prformance instrumentations.
3. TTKGVTCDG corrected from 0.65 to 0.35
At one stage the OEM told us that the exhaust Thermocouple lag could be the case. In other words, the TTXM will take some time to pickup the increase in the exhaust temperature and as it picks up the FSRT is reduced accordingly. However, we proved to them that this is not the case. We did the test by raising the MW slowly at 0.5MW/minutes and when we hit the baseload the unit output just dropped by the same amount.
What is puzzling us, there are many department in the OEM and they are giving contradicting answer, some agree that this is abnormal and some say it is normal. We did ask from the OEM if this phenomenon is common accross the fleet and provide us with the information, but they never replied to this specific query...at least until today.
Recently they suggested to change TTKXCOEF_1 from 0.98 to 0.99. We have not done this yet. Also there are some talks I heard from the OEM on the temperature control curves.
Appreciate if anybody can share experience on this. I welcome any suggestion and opinion from all the expert in this forum.
