I'm looking for a multi-point (maybe 8 to as many as 20 points) characterizer/linearizer module that can be configured or programmed with a table of values such that 4-20mA input gets retransmitted as a characterized 4-20mA output, per the table of values.
I've done this on some recorders or larger systems that had look-up table functionality, but I now have several needs - characterizing signal to a valve positioner, and corrected level for a hopper that isn't flat bottomed without either fancy recorder or system capability. Just a 4-20 signal and a need to characterize it.
Is there such a black box instrument?
David
David
