I'm a final year engg student of elex and instrumentation.. My major project is Weather monitoring system using PLC.. It was just a topic i chose with no prior knowledge of what the project is supposed to do..
As i worked upon, i planned the sequence of the project.. i decided three major parameters to be sensed: temperature, atm pressure and humidity.. but i stopped at 'PLC'.. i'm not aware if it takes analog inputs and can perform a check that whether the input lies in a specified range or not? For eg, i've been suggested that the plc program should be able to indicate somehow when temperature exceeds 45'Celcius.. Is this possible through PLC?
Moreover i'd like to know is this project good enough for final year of engg?
