I have to convert (re-write) some logic from a printout of the ladder. The new PLC will be Allen Bradley (no problem there). I believe the old PLC was a TI because "X" is used as an input, "Y" is an output, "V" is variable memory, etc.
However, there is an instruction that I don't recognize... The rung has an open contact with address "SP1". This open contact leads to a stack of blocks on the rung output. The first block is "LD" with address "VC40", next is "OUT" with address "V200", then LD VC80, then OUT V2001.
Can anyone give me some help on this rung?
