N
Need very low cost flow switch for battery powered application - suitable for insertion in 1/2" water supply pipe.
My basic requirement is to wake-up a microprocessor when flow occurs in a water supply pipe. The pipe would be either steel or PVC. The size is in the 10mm to 1/2" range. Normally there is no flow but several times each day flow will occur and this is when I need to wake-up my (embedded) system to collect data.
Initial annual volume is in the range 1K-10K. The cost target for the complete sensor including pipe fittings and seals etc. is 7-8 Euro.
The ideal solution would be something like mounting a saddle bracket on the pipe. To drill a hole through the bracket into the pipe, and to insert some tiny solid state sensor into the pipe.
I've found some anemometers that are printed on ceramic thickfilm and coated with glass. These are low cost, very robust and they have excellent dynamic specs. The "only" problem is standby power consumption :-(
I'm now thinking about building a piezo electic element into a flap that vibrates when flow occurs and thereby generate a wake-up signal. I have a micro controller in the system and the ability to adapt to almost any kind of signals on the analog side.
Any references to part suppliers or alternative ideas are more than welcome!
Best regards,
Niels
Best regards,
Niels
