I have a pump to transfer water from tank A to tank B. Required control:
If tank A level is high, pump starts, level low pump stops.
If tank B level is high, pump stops to prevent water wastage, level low pump starts again
That is
Pump starts if (tank A high) and (tank B low)
Pump stops if (tank A low) or (tank B high)
What would be the most economical way to achieve this? The two tanks are rather far from each other. Pls give me advice. Thks alot!
That is
