I need to communicate with a DDE server running on a VAX (This is a Wonderware product called NetDDE for VMS). I have found that NetDDE Extensions (A common component installed with Wonderware InTouch) must be installed on the PC to link to the VAX. The reason for this is the Microsoft NetDDE only works with the NetBEUI protocol, but the VAX DDE Server only works with TCP/IP. Do you know of any other PC product (for NT) which will allow NetDDE over a TCP/IP protocol?
