Netscape 6 - does anybody know a hack?
jackh
I just discovered that the new Netscape 6 browser is 'suddenly' not allowing remote applets to access remote resources, such as TCP/IP
connections. This is because of applet signing, which is a feature available in the Java 2 (ver. 1.3) toolkit. It seems to be rigidly enforced in Netscape 6, so I can still use appletviewer to use the applets, but when tried with Netscape 6 it claims security violations and quits. (I could have sworn that I was getting access to the applets a few days ago with Netscape 6.) I can still use the applets with Netscape 4.72. Does anybody know how to get around this?
BTW, Netscape 6 is extremely buggy, and seems to have fewer features - it feels like it has been steered more by the commercial AOL interests
than the GPL developers. In the mid 90s AOL introduced the worst users and abuses to the internet, remember publicly writable FTP sites, and when spam got a user cut off? Are they doing it again with Netscape?
Note: You can run both the new and old browsers on the same machine at the same time. But, I don't suggest deleting the old one just yet.
Hugh
LinuxPLC mailing list
[email protected]
H
Harald Albrecht
> TCP/IP connections. This is because of applet
Jar up your classes and drop the jar file into
your JRE's extension directory. The extension
directory is usually called 'ext/' and is below
the 'lib/' directory. Make sure that
'lib/security/java.policy' grants all
permissions to all Java extensions lurking in
the extensions directory:
grant codeBase "file:${java.home}/lib/ext/*" {
permission java.security.AllPermission;
However, this is only a "hack" to get things
working. In the long run I would suggest to
separate the classes or packages that need
privileges and only store them locally in the
extension directory. Although you have now to
"install" those classes explicitely in the
appropriate directory, you can skip the signing
step.
Harald
Harald Albrecht
Chair of Process Control Engineering
RWTH Aachen University of Technology
Turmstrasse 46, D-52064 Aachen, Germany
Tel.: +49 241 80-7703, Fax: +49 241 8888-238
[email protected]
Here's some fuel for the conspiracy fire, I just found that the applets will run under Netscape 6, in windows, but not under Netscape 6 in Linux. This is very troubling, but I assume a sign of things to happen to windows.
Also, I was hoping to avoid the type of solution Harold suggested. After all, the attractiveness of Java is that the user doesn't need to have
any idea about what they are doing, and doesn't have to have any software installed. And, that is why I moved away from file based IO towards sockets only - because the user could avoid the security policy issue. With these changes it only makes it more like traditional software, and more confusing for the user who 'only wants to get the
thing working'.
Hugh
[email protected]
