K
we are in the process of commissioning information links between plcs and a dcs system. there are 12 plcs of different makes (ge fanuc, allen bradley, schnider and saia). opc server is intalled in each of the plcs and opc client is configured in dcs. dcs ip are class B private (172.16/17.xx.xxx) with a dual homed pcs with additional NICs for opc interface (172.18/19.xx.xxx)
to maintain connectivity with dcs, i am forced to change the ip addresses of plcs system noded to 172.18/19.xx.xxx, as they do not have an additional NIC. As a requirement of opc connectivity, the login (username and password) has to be the same at both dcs end and plc end. with this each plc connected to dcs is becoming an authenticated user to every other plc. all the resources shared between the pcs in a given plc are also beocme accessible to other plcs. is there any way i can maintain each plc in its own island / domain?
i also need help regarding what is the safe method of connecting plcs to dcs. do i have to install a 3rd NIC in each of the plcs nodes running opc server?
