What I have learned from a career in engineering:
1. We work and play in ongoing dynamic time, but all our logic, arithmetic, and machine control is confined to timeless static frames. We can speak of and write about circuit, machine, and animate behavior, but the fundamental operators of ordinary logic can only describe static states, not dynamic activities.
2. Behavior emulation using standard logic is therefore limited to still frames stitched together with clock pulses or many lines of linear-sequential code (software) like a child’s connect-the-dot drawing. That is why there are millions of lines of code in some programs.
3. There is a dynamic alternative to computation for process management. It is truly real time, it is parallel-concurrent, and it reacts immediately to changes. It has 100-times fewer components, is 100-times faster to respond, has little or no run-time software, and it is safer. Control circuits and systems designed and built to this method would be improved and cost less.
I offer to prove the truth of the first two statements (for those who do not already believe them) and demonstrate the truth of the third statement.
