Nirvana Air compressor
Bala
Face VSD8 error in Nirvana 75KW air compressor. Rotor does not seem to rotate. No voltage, amps, rpm.
Changed control board, interface board, output module, stator & rotor but still problem persists.
Y
Yeasir Rahul
Have you changed the hall-sensors? VSD 8 error is "Encoder Loss".
>> Changed control board, interface board, output module, stator & rotor but still problem persists. <<
> Have you changed the hall-sensors? VSD 8 error is "Encoder Loss". <
The problem was occurring for a new hall effect sensor received from vendor. Replaced a spare (slightly damaged) hall effect sensor and observed the rotor to run for a few seconds but trips with VSD 7. Is there any procedure to check the hall effect sensor working condition without the special kits.
