Null modem
Gary Stanton
I have an application requiring a 9-pin male to 9-pin male null modem adapter. Pinouts PLEASE!!!!!!!!!!
Gary Stanton
SBV Automation cc
PORT ELIZABETH
Tel/Fax:- +27 41 3608205
Cell:- 083 222 9546
Allan Chinchilla
3---------------------------------2
2----------------------------------3
7-----------------------------------7
Cheers and Good Luck
Allan Chinchilla
Johan Bengtsson
9-pin NULL modem:
1,6 - 4
2 - 3
3 - 2
4 - 1,6
5 - 5
7 - 8
8 - 7
pin 1 and 6 should be connected together at each end and then connected to pin 4, this means you need 8 wires for the cable.
It might be enough to use a simplified version where only pin 2,3 and 5 are used, wired as above.
/Johan Bengtsson
P&L, Innovation in training
E-mail: [email protected]
Internet: http://www.pol.se/
L
Lloyd Sumpter
Be aware that there are MANY types of "null-modem" cables. The TX and RX are always crossed, but some cross DTR and DSR, others short them together, or pull them high (actually low: -12v is a logic ONE), and so on. If you use a
"standard" one, it may work or it may not, depending on how the software at each end use the handshaking signals like DTR/DSR, RTS/CTS, etc.
Lloyd Sumpter
LSumpterConsulting
H
Hevelton Araujo
DB9 DB25 PIN PIN DB25 DB9
3 2 TX ------------------ RX 3 2
2 3 RX ------------------ TX 2 3
8 5 CTS ------------------ RTS 4 7
7 4 RTS ------------------ CTS 5 8
6 6 DSR ----------------+- CD 8 1
4 20 DTR -+ +- DTR 20 4
1 8 CD -+---------------- DSR 6 6
5 7 GND ------------------ GND 7 5
- 1 CHG ------------------ CHG 1 -
Good Luck !!
Hevelton Araujo Junior
Ger=EAncia de Engenharia
Tel.: +55-31-34275852
Fax.: +55-31-34912077
E Power Generation 3
G Process Control 4
T General Communications Chat 6
H General Communications Chat 2
A Computing 4
