Oil in condensate process line
  • Thread starter Dittrich, Rodolfo
  • Start date
Dittrich, Rodolfo
Hi all,
I'm trying to find the best way to measure oil in a condensate process line. The line should carry condensate at 40..60=BAC at a pressure of 2Kg/cm2. I need to detect the presence of oil in that line to prevent damage of other equipments.
Somebody could help, telling which is the best way to detect this condition.
Thank You,
Rodolfo
L
Larry Kolbert
A gamma density gauge may be a solution? Several companies make such a device, TN Technologies being one of them. Web is TN-KSI.com.
L. Kolbert
W
William L. Mostia, Jr
I have no experience with this meter but it may meet your needs:
Red Eye
Premier Instruments, Inc.
10801 Hammerly, Suite 232
Houston, TX 77043, USA
713-461-7995
FAX: 713-461-2675
William(Bill) L. Mostia, Jr. PE
Principal Engineer
WLM Engineering Co
Independent I&E Consultant
P.O. Box 1129
Kemah, TX 77565 USA
281-334-3169
E-Mail: [email protected]
These opinions are my own and are offered on the basis of Caveat Emptor.
You start with a bag full of luck and an empty bag of experience. The trick is to fill the bag of experience before you empty the bag of luck.
Adolfo Jimmy Saldivias Valarezo
Larry:
I have the need for gamma density gauges, and so far have been able to only find TN technologies to manufacture such a product. Would you guide me to other manufacturers?
Thanks Jimmy
Saldivias TECSIM Phone:
591-4-523438 Fax: 591-4-523413 website: http://tecsim.trading.net
R
Rodney Stevens
A search of the web will give you any number of hits on nuclear density gauge suppliers. You should be able to find one.
Amdel and Scantech in Australia use to supply density gauges. If you have a one off application that commercial units can not handle,
we build and supply nuclear based instruments to the Oil and Minerals industry.
Rodney Stevens
CSIRO Minerals
http://minerals.csiro.au
Ph. 61 2 97106701
Fax 61 2 97106789
Elan SS s/e 45/7616
http://sites.netscape.net/rodjohnstevens/homepage
If i assume you are looking for trace quantities, you might try Rivertrace engineering at http://www.rivertrace.com where they have p.p.m. measurements (essential for pollution control aboard ships and in industrial installations). There are, i believe, other manufacturers but this is the only one i have looked at.
