Does anybody know where I can find the GSD file (OC_1656.GSD) for the OMRON C200HW-PRM21? It is featured in the manual but does not appear on "Profibus.com":http://www.Profibus.com or any OMRON website that I can find.
Hello Brent;
Omron states that the gsd file is available on their Syscon-DP configuration software disquettes. It also claims that you must use their Syscon-DP to integrate that Profibus-DP master device.
If you need the gsd file quickly, look in appendix B of the following Omron document:
It contains the gsd file in printout. You need to copy the text in any unformated text editor (Notepad works well). You then save the file as OC_1656.txt, and rename it as OC_1656.gsd. I've done it before;it just takes the time to copy the text accurately.
