hey,
i am having a little problem on the omron's fin command. i couldn't specify the start dm address of more than 255 since the byte array can only contain a maximum value of 255.
byte[1] = 0x00;
byte[2] = 0xFF;
i am using byte array to contruct the whole frame in C# and it is a must for the socket to deliver the message. how am i gonna read dm address of 300? it will not work if i put like this,
byte[1] = 0x01;
byte[2] = 0x2C;
it will be intepreted as a value of 144 instead of 300. i cannot use string array because the array must be converted to byte in order to use the socket.
thanks indeed.
byte[1] = 0x00;
byte[2] = 0xFF;
byte[1] = 0x01;
byte[2] = 0x2C;
thanks indeed.
