Good day, I have 2 cat generators (1.5MVA) in parallel, whenever there is a power utility failure, the two gen start (gen1 has priority over gen2) and they are loaded, after few minutes the gen2 drop load and show reverse power trip alarm When I try to clear the alarm on gen2 and put it on auto to start in parallel with gen1, afer it sync (loads) with gen1 few minute its dropped load and popup reverse power What are the causes or reverse power in generators? What are the causes or reverse power in generators?alarm.....One thing I discovered was that when gen2 sync and load with gen1, I noticed Gen1 power start increasing instead of dropping since gen2 has sync and loaded, after gen2 popup alarm the gen1 goes back to its normal power value
PLEASE WHAT COULD BE THE CAUSE OF THIS.......... Your answer will be appreciated
