I noticed in the BBL FSRNV3 “Speed Control FSR“ that there are two control loops:
Loop 1: The upper control loop with TNKRNR signal as reference and TNH as feedback.
Loop 2: The lower control loop with TNR signal as reference and TNL as feedback (or TNH if the OVERSPEED test is selected).
And the outputs of these control loops are the input of a Minimum Selection block.
I have 2 questions:
1) Under which conditions we can have loop 1 active, and under which conditions we can have loop 2 active.
2) In this block, FSRNV3 there is a logic signal L83SCDB, is represented as and input to this block. I searched in the CSP for the source of this signal but I couldn’t find it. it is used only in this block. I want to know the source of this signal and also the operation of the loop when it is enabled.
For your information, I found the state of L83SCDB signal in rung display to 0. And the machine is MS5002C (TWO SHAFT MACHINE) which drives centrifugal compressor with Mark5 control system.
I have 2 questions:
