Hi all
I'm still "listening" but need more time for coding. I played some with the Opto Enet rack today and got more serious about Modbus/TCP. It seems the Opto "Brain" (isn't that corny) "supports" Modbus/TCP, but does it in an interesting fashion. Reading digital inputs you get 1 input per address as a 16 bit "register". I was expecting some way to pack several inputs into a register for efficiency. It seems you get 0 or 255, not 256 like if you had the bytes swapped? more on this later. I'm gonna write a packed dumper so I can see what's really going on.
They also talk to it in an IEEE1394 "firewire" packet format over TCP. Since this supports "quadlets" and bitmaps I would guess it's more efficient. I wonder if they didn't cripple the Modbus just a little to steer you to their proto. Has anyone seen anything else that uses the IEEE1394 block format? Would it be worth implimenting?
Curt Wuollet,
Wide Open Technologies
LinuxPLC mailing list
[email protected]
Curt Wuollet,
[email protected]
