H
I have a problem in output module from GE Fanuc, I need energize a single phase Eurotherm SSR, the output module have output circuit style Triac, the SSR work with 100Vac and output module work with 115Vac, the problem is that with the output circuit disabled (output OFF) the SSR is enabled (go to ON state), can I put a device that avoids this problem?, the output module is IC693MDL330. Thank you. Hugo Magallanes
