Hello everybody!
I have some doubts about overload-relays,
Siemens sirius overload relays have got a blue reset button which you can set-up on manual or automatic mode,
Lets assume that this overload relay are related with water pump and auxiliary contacts are connected to PCB,
In case of over-current:
When relay is set-up on automatic: relay will tripped and you will need to reset him(by hand)?
When relay is set-up on manual: relay will not tripped (even if current will extend set-up value on the relay)?
Am i right?
Or im wrong?
Am i right?
Or im wrong?
