L
Currently, I am doing an upgrading project, which employed Profibus DP network consist numbers of Siemens S7/200,300 PLC, a HMI station monitors the building condition, retrieves data through an Applicom card, from which to exchange data with EM277 DP module.
We purchased two PCU1500PFB brand new cards and finished the design on software and Hardware redundancy. However, a crucial problem been found and the whole thing go to a halt.
A DP slave always needs to exchange data with the only master in this network to get the configuration and identify itself when power on. Things happened when power cycle the PLC, all the WO* registers contain PID setting will be overwritten to zero. Moreover, all those WO* are controlling the PID output to maintain the temperature and relative humidity in side the CleanRoom¡¡..
According to the Em277 spec, applicom will store output data form HMI and write cyclic to the PLC. If disconnect the profibus connector the V memory will still be kept. Looks like Applicom card wipes all data after recognizing the Slave.
I have contacted and ask the local Tech support staff to come and help, he left with no result.
Any help will be appreciated. Thanks
Li Wei Shi,
A-control.Pte.Ltd
Li Wei Shi,
A-control.Pte.Ltd
