I'm having to build a PV application without an actual Panelview, so I can't experiment. I'm doing a project with PB32 for a standard PanelView 1000. How do you link the Move Up/down buttons to a specific tag or control? I wanted to set a tag value with an Inc/Dec entry thats part of a controller station graphic with its own arrows. On the same page, I want a control list selector with associated arrows to select one of several variables to be affected. Can this be done? I've been all over the 'net, Rockwell and AB docs, etc.
Also, when mapping 2,16-bit tags to a 32-bit DeviceNet input, what is the correct way to specify the high-order word as the destination of the second 16-bit value? ie: if tag1 goes to I:5, can I address tag2 to I:5/16?
Dan
Dan
