N
With all due to respect, we'd like to ask you a favour.
Basically, we have 8 nos of isolation transformer configured in parallel. Each transformer has the same specification and made from the same manufacturer. The transformers are designed for standby if in case of UPS system fail/down, then transformers will take over the load. The static switch (inside UPS) will transfer the load to transformers (in other words: internal by pass) if in case of UPS system fail/down. Current condition of the transformers are no load.
We kindly ask your analyze based on our information mentioned above. Is there any risk or damaged will happen during the transition from UPS to transformer?
Thank you.
Thank you.
