Vladimir:
> Generally speaking as a matter of fact, Internet makes life too unsafe...
> and instable. The ability to control has reduced to the knowledge of
> password (think, it is just a short sequence of chars)...
Fortunately, these days systems can be configured to use better (or worse) authentication methods than that. Normally this means some sort of
challenge-response system based on some piece of hardware, either manual (type number into calculator, type back the response) or automatic (plugs into USB port or a special reader). Some of the ones that plug into a USB port even fit on a keyring with normal keys...
Obviously, this depends on the owner having it set up in the first place, and then ensuring that it stays set up that way.
Jiri
Jiri Baum <[email protected]>
http://www.csse.monash.edu.au/~jiribvisit the MAT LinuxPLC project at http://mat.sf.net
Jiri
