T
Initailly I want to use PC to control temperature in an electric furnace up to 1600 deg F and log the temperature data.
A few requirements for the temperature controller.
- 5 sec max temp scans for control out of tolerance conditions and visual monitoring (dont think that should be too hard)
- Audible alarm for out of tolerance conditions
- External light indicator for out of tolerance conditions
- External light indicator for warning limit conditions
- Ability to regain control, after shut down due to out of tolerance condition without having to cool specimen down a few hundred degrees. (Current control software requires this if you dont want to wait a few hours for it to figure out where it is)
- Ability to have separate PID’s for each temperature. (all tests have one temp for the entire test but different tests require different temps)
- Automatic PID tuning.
P.S. I am not an engineer or programmer but have been working with temperature controllers for 16 years.
Let me know if you need more info.
Any help would be appreciated.
Todd
Todd
