I have a need to connect a PC to a GE 90-30 PLC to get certain I/O status information. Has anyone done this that can tell me what I need to install Hardware/software?
Look at www.kepware.com/GE_Fanuc_OPCServerSuite.html - Kepware OPC servers for GE. They will handle communications with the PLC and will provide an DDE server for any DDE client (such as Excel, HMI, etc.)
You can use the DDE server from Wonderware.
GESNP for serial and GEHCS for Ethernet.
Both will allow Excel to read and write info to the PLC.
You can also check out Kepware drivers.
1. Through Versapro, ladder program supplied by GE Fanuc which supports SNP protocol, you can upload the program and monitor the status
2. If you SCADA package, which supports SNP ( Series Ninety) protocol, then you can use it to get the data
3. I hope GE-Fanuc PLCS Versa Max Micro/Versamax both supports Modbus RTU protocol, so the higher level 90-30 will also may support Modbus RTU protocol. Through Modbus interface, you can get the data.
<pre>
The Modbus address GE Fanuc Address
