Hello I've had a hard time to find a PC104 board that fits the following criteria.
256K/512K boot Flash ROM
Real Time Clock support.
Need 128k of application memory at least and limited DOS calls.
no serial ports.. if any they are Com1 and or Com2
no parallel port.
186+ cpu
FPU emulation OR can run a Borland C++ 5.0 executable with FPU emulation
enough RAM to run FPU Emulation and the application in memory.
<256k about>
Is cheap.
Unit
At the moment I am building a AMD188ER PC104 board to use for this that will have the code run in Flash ROM and will need no extra RAM other
than the 32k with the ER and be dos compatible <mostly
> I need something in between to run the program while this is being debugged <fun fun>.
Suggestions? Caveats?
Flames, bashing will be ignored, suggestions welcome, ideas welcome, and
insights welcome.
no parallel port.
186+ cpu
<256k about>
Is cheap.
Unit
insights welcome.
